Can't decide which case to pick!
29 Jun 2010
Well I am currently stuck and don't know what case to pick out of these 3 choices:
Fractal design R2
Antec mini P180
Lancool PC K62
What one would you go for?
The Antec is the mini version, not full size, not really fair comparison, are you using mATX build? If so go for the Antec, used to have original P180 and it was very good/excellent, plus if you are mATX then the mini would presumably take up less space (cant be bothered to check)
Havent used either of the other two but from reading around the fractals are popular choice/well regarded so if full size build go for that I guess
well i have chosen the components for a matx build and standard size build so i can choose either of the 3 cases. I think the antec holds its own even though it's not full size and i prefer it over the bigger version. (plus the mini p180 is not a whole lot smaller than a full size case).
I love my Lancool, great for air cooling.
But the Fractal looking more sleek.
Either way, i think youll be delighted with both
Have you looked at youtube reviews??
6-4 to Lancool, but i think i might be going with the fractal as if it i get the lancool i will have to spend ages braiding/making everything look neat. Plus i like the idea of having the sound dampening. But saying that the lancool looks like it would be a lot easier to build in. Man this is a hard decision!
