Cant defrag my C: drive!
18 Oct 2002
Newcastle, England
For some reason I cannot defrag my C: drive, it just refuses to do it on a reeboot using perfect disk. I tried O&O and it goes through it in windows but the files are only about 1% defragged.. help?
You mean the info file before you defrag?
I could but i dont think it will help you. I thought it might be because i switched my page file to another drive but thats not it. Perfect disk says it cant get access to the c: drive for some reason and says do it on a reeboot.. i do and it says there might be a driver conflict? I cant see any.
This one
I was thinking this also.. I thank you for your help. I will free up some space and try again.
Thanks again wizardmaxx. :)
Just to say also, i am trying to shift files and folders on to my maxtor and the pc just froze. Its unfroze now but taking an age to transfer a 1.37 gig folder.
Ok thanks, I have disabled my Kaspersky and no go. I unplugged my maxtor and still theres a problem. Perfect disk says there might be a driver conflict although i can find none. Theres something not right though, it locked up transfering files for ages.
I'll do some investigating and report back soon. :)
I dunno theres some really strange stuff going on here. I ran Windows defrag and it ran fine, then when I analyze it says it dosent need defraged, but when i run perfect disk, it looks totally fragged??
Jimbo said:
I dunno theres some really strange **** going on here. I ran Windows defrag and it ran fine, then when I analyze it says it dosent need defraged, but when i run perfect disk, it looks totally fragged??
Edit the sweary imo. Dons are in a bad mood today as it is.
Jimbo said:
What do you mean I already have. :confused:
Fully.
First you had s and h
Now you just have s.
Needs to be fully, you should know that being a senior member.
