it used to work fine but for the last 2 weeks i can get my 2 pcs to connect to each other properly
they both connect to the same switch and after disabling all firewalls,
they can ping each other fine,
i can see the other PC in net places and see the shares but it times out accessing them
i havent disabled any services or anything on either one. the XP firewall is off.
i was messing around in the last few days on getting vista working in virtual PC so decided to test it with that to find out which pc was to blame. stupidly, both pcs share files fine with vista, just not with each other.
help
p.s
both main pcs are on xp pro - sp2. all firewalls disabled etc
help
p.s
