hi,as the above really.looked in the genie bios section and it isnt there,nor is it in the dram config section.any ideas because i really cant see it anywhere unless its under a differant name/term?
If you go to genie bios/Dram configuration,you'll see cpc(command per clock) this is what you're after,enable = 1T/disable = 2T,auto will select 1T if you're ram is suitable.
