I am trying to fit my black ice stealth 360 to my case and the screw holes in the radiator seem just a lil bit too narrow. I fit the three GT fand to the rad just fine but the screws just wont fit. Which am I supposed to use?
If the fans fit the rad and your case try screwing each one a little bit at a time. I had this problem to when I just tightened one end and the other wouldn't fit in at all but putting them all in a little at a time made it all line up straight.
I am gonna wait till my dads home, he would be better at that bit lol.
Just sad I have built probably over a dozen systems before lol ... and i'm 28 :|
I can't tell what the issue is from the OP, is it that the holes don't line up or is it to do with the size of the screws? Are you going rad-fan-case or fan-rad-case? What type of screw did you use to fit the fans to the rad? Self tappers, fan screws, M4 machine screws?
tbh i dont let my dad touch my computer stuff as the first thing i got him to do when i was about 8 was to put an external dvd drive into a usb housing for use with my laptop and he mullered the screws and scratched all the outside of the housing doing it
