Can't format USB stick to NTFS
  • Thread starter Thread starter Pug
  • Start date Start date
Pug
Pug
20 Oct 2002
Over there...
Getting fed-up with this now!
Bought a generic 16GB USB stick for transferring big (8-12GB) files about, and so need to use NTFS.
In win 7, and in XP, i cant format to NTFS. All of my other hard drives are, but this one cannot.
I read that i need to alter it in device manager to "optimise for performance" to "unlock" NTFS in the formatting options - and its setup to do this now, but it still errors when trying to format to NTFS.
I can format to FAT32 easily, but errors everytime for NTFS. Fed up, so please help.
EDIT: Tried with another flash drive i have knocking about (cheapy 1GB one) and that works fine, so i guess its the drive?)
I formatted loads of USB drives as NTFS in Windows 7 and never had an issue. You either have a dodgy USB drive or it is just crap! :p
Give GParted a go as mentioned above. :)
well, trying gparted but thats proving trickier (via USB) as all three methods do not let me boot (i know what i'm doing to :p ).
tbh, i cba, i have never had this issue before, all my other ones work fine, i'm either gonna use it as a FTAT32 or get a refund.
buy cheap, buy twice...
yeah, should have said i already tried that. Drive disconnects (accroding to a popup from CMD)- thanks for the suggestion tho :)
its just crap, blatantly.
Have you tried using Diskpart?
Open Command Prompt with admin rights and type the following
DISKPART
LIST DISK (make a note of the number your flash drive is >DO NOT GET THIS WRONG<)
SELECT DISK (enter whatever number your flash drive is)
CLEAN ALL (clean and zero write)
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
