- 22 Sep 2006
yo i manage to get my AMD Athlon 3000+ 2.0ghz at 2.35ghz not much of a change i no, the temps are fine and the system is runnng stable its running at 1.55V which is maximum and the multipler is on a default 10X but if i go to 2.4 it boots to when it loads XP then goes back to the original bootup screen and starts the procces again, am i running my RAM to fast??? i have a ASrock K8-Combo Z with M1653 chip anysuggestions so i can get this clockin higher
thx
