Can't get F@H to work
5 Oct 2009
Spalding, Lincs
A few months ago I re-installed F@H but had problems so I just have up. Thought I'd give it another go now I'm on a fresh install, but the exact same problem remains.
So problem is that it won't download the WU's, here's part of the log:
Code:
20:58:54:Saving configuration to config.xml
20:58:54:<config>
20:58:54:  <!-- Network -->
20:58:54:  <proxy v=':8080'/>
20:58:54:
20:58:54:  <!-- User Information -->
20:58:54:  <passkey v='********************************'/>
20:58:54:  <team v='10'/>
20:58:54:  <user v='andy_mk3'/>
20:58:54:
20:58:54:  <!-- Folding Slots -->
20:58:54:  <slot id='0' type='GPU'/>
20:58:54:  <slot id='1' type='CPU'>
20:58:54:    <cpus v='-1'/>
20:58:54:  </slot>
20:58:54:</config>
20:58:56:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
20:58:57:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
20:58:57:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
20:58:57:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
20:58:57:ERROR:WU01:FS00:Exception: Could not get an assignment ID
20:58:58:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
20:58:58:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
20:58:58:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
20:58:58:ERROR:WU01:FS00:Exception: Could not get an assignment ID
20:59:40:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
20:59:41:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
20:59:41:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
20:59:41:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
20:59:41:ERROR:WU00:FS01:Exception: Could not get an assignment ID
20:59:57:Saving configuration to config.xml
20:59:57:<config>
20:59:57:  <!-- Folding Slot Configuration -->
20:59:57:  <power v='full'/>
20:59:57:
20:59:57:  <!-- Network -->
20:59:57:  <proxy v=':8080'/>
20:59:57:
20:59:57:  <!-- User Information -->
20:59:57:  <passkey v='********************************'/>
20:59:57:  <team v='10'/>
20:59:57:  <user v='andy_mk3'/>
20:59:57:
20:59:57:  <!-- Folding Slots -->
20:59:57:  <slot id='0' type='GPU'/>
20:59:57:  <slot id='1' type='CPU'>
20:59:57:    <cpus v='-1'/>
20:59:57:  </slot>
20:59:57:</config>
20:59:58:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
20:59:58:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
20:59:58:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
20:59:59:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
20:59:59:ERROR:WU01:FS00:Exception: Could not get an assignment ID
21:01:17:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
21:01:18:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
21:01:18:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
21:01:18:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
21:01:18:ERROR:WU00:FS01:Exception: Could not get an assignment ID
21:01:35:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
21:01:35:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
21:01:35:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
21:01:36:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
21:01:36:ERROR:WU01:FS00:Exception: Could not get an assignment ID
21:03:54:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
21:03:55:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
21:03:55:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
21:03:55:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
21:03:55:ERROR:WU00:FS01:Exception: Could not get an assignment ID
21:04:12:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
21:04:12:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
21:04:12:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
21:04:13:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
21:04:13:ERROR:WU01:FS00:Exception: Could not get an assignment ID
21:08:09:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
21:08:10:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
21:08:10:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
21:08:10:WU00:FS01:Connecting to assign3.stanford.edu:8080
21:08:11:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
21:08:11:WU00:FS01:Connecting to assign4.stanford.edu:80
21:08:12:WARNING:WU00:FS01:Failed to get assignment from 'assign4.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
21:08:12:ERROR:WU00:FS01:Exception: Could not get an assignment
21:08:26:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
21:08:27:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_UNKNOWN
21:08:27:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
21:08:27:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_UNKNOWN
21:08:27:ERROR:WU01:FS00:Exception: Could not get an assignment
I never had any issues before. Any ideas?
Running Windows 7 64, i5 2500k, AMD 6950.
Edit: So 20 minutes later my GPU has burst into like, but still no WU for the CPU. And I think last time it also did this, after completing the WU it couldn't download another.
Edit 2: Disabled my AV, still the same. Uninstalled it and restarted and it picked up a WU. I'll see how it goes :D
Seems to be yes. Looks like the anti-virus wasn't playing ball. Installed MSE now and it's fine. Getting 30k PPD from my 2500k and 6950.
