Can't get intel burntest to work
17 Aug 2009
Finchley, London
Works on my desktop, but I keep getting this message on my laptop when I click on IntelBurnTestV2.exe. Any ideas how to get it working?
Move the .exe outside the folder ;) not inside it :)
Thanks. It didn't work but I just figured out the problem. I was dragging all the files from the zip to my folder and it didn't create the needed 'LinData' folder.
But when I extracted via winzip/actions/select all/extract to, it creates the needed 'LinData' folder and works. :) Weird, I always thought you could just drag files from winzip to a folder, didn't think it would make a difference doing it the long winded way.
How many threads should I set it to? I'm going to test on maximum stress level. It's i5 dual core plus 2 virtual cores.
