Can't get mem to run at 1866mhz
30 May 2013
Hi all,
Upgrade build to..
AMD A6800-K
8GB Patriot Black Mamba 1866
Asus F2-A85X-M le
It runs O.K always at 1666mhz until I try to get full speed from memory then it comes on momentarily, and base unit stays on but monitor goes to stand by. I am using default setup for everything.. ( cos I'm a noobie, and don't know any better !!)
and my Asus BIOS is 5105.
Any help appreciated.
Make sure you set the timings that are specified for the memory kit.
Thanks for reply.
Set to 9-10-9-27 as stated in Patriot spec. below.
Tried 9-9-9-24, but that was no respons at all !
Series: Viper 3
Edition: Black Mamba
Capacity: 8GB (2 x 4GB) Kit
DIMM Type: 240-Pin NON-ECC UDIMM
Voltage: 1.5V
Tested Frequency: PC3-15000 (1866MHz)
Tested Timings: 9-10-9-27
Base Frequency: PC3-12800 (1600MHz)
Base Timings: 9-9-9-24
Tested Platforms: Intel® 6 & 7 series
Feature Overclock: XMP 1.3
