Cant get my first PCI-E card to work
8 Jan 2004
CORNWALL
Bought a second hand 7900gt (came alone) then bought 6pin power cable and VGA to DVI convertor (for the monitor)
No luck geting it to work
Motherboard: Click here
480W PSU
have I missed something? :(
EDit: oops :d
Do you mean PCI-E? Don't think theres a PCI version...?
Whats actually happening? Does anything display on screen at all? Does the fan on the card spin up?
Have you gone into the bios & turned the onboard graphics off? or set your primary graphics to pcie instead of onboard?
the fans spin, blank screen. Few stupid questions
Does it matter where i can connect the monitor DV1 or DV2?
I got onboard card, do i need to disable it?
EDIT: i will try disable now, cant you do it through Device Manager? :D
sorry to bring this back, straight away nvidia software is telling me not enough power, so settings are lowered to prevent damaging hardware.
Now, I got a 480W Thermaltake PSU Click here with
Motherboard
1 x gfx card
1 x HD 80GB IDE
is there a setting i missed or a mistake by me? or do I need a need psu? :)
