Hi all, I'm a bit of a rookie at this so please be easy on me
I have a ROG Maximus XII Hero mobo and I installed the Vengeance RGB Pro DDR4 PC4-25600C18 (2x16gb @3600mhz)
I have went into my Bios and set the XMP profile 1 but the best I can get the memory to run at is 3000mhz even if I set the XMP to profile 2 I still cant get better than 3000mhz, If I do set the memory higher I get the crash screen.
Do I need to change something else?
Thanks.
Thanks.
