cant get rid of standard vga adapter after uninstalling drivers
22 Nov 2002
Liverpool
Hi, i was using catalyst 10.11 and installed 10.12, then my catlyst control centre wouldn't work any more, i uninstalled the driver software and then uninstalled the drivers by going to device manager and clicking uninstall and clicking delete software.
everytime i now restart my laptop it will only install a standard vga adapter, i have tried manually updating and it says it can't install the drivers etc...
I am using windows 7 64 bit, the drivers i have are also win 7 64 bit.
Can anyone help i really wnat my system back to normal with the right video settings, my system restore is turned off as well from when i had a virus and i forgot to turn it back on.
Can anyone advice please?
James
Have you tried -Left Click my computer-properties. Uninstall Graphics card Driver, but do not restart. After Uninstalling the Driver, go straight to your new driver and if it is an .exe, click and install. If it's a zip, zip to a folder and point to it to install. Hope I've explained this ok for you.
