- 8 Jan 2008
hi all, i need some help and advice , i have a synology NAS for my music photos and video , i had a home hub 1 in the past and the UPNP worked 100% , i have now tried a Home Hub 2 and 3 but whatever i do cant get the UPNP to work , i can map drives no problem but cant see the Synology at all using UPNP .
i have half solved the problem by connecting everything hard wired with TP link hubs and all is ok for wired devices but wont work for wireless devices ( as these go through the Home hub ) , do i get a new router or add a wireless access point to my network connected to one of the hubs that fully support UPNP , im also about to upgrade to BT infinity , any suggestions ?
Thanks
Thanks
