- 12 Mar 2008
I'm using a tiscali router, and I'm connected via a cable with one computer to that, and that's all fine.
However I can't get another older computer to connect to the network. I'm using a Netgear WG111 Usb wiresless adapter in that computer, and I've installed the software. When I try to connect to the tiscali router it says something about security and that I need a WPA2-PSK passphrase?? What is that, and how do I get it?
thanks for any advice.
regards
phil
regards
phil
