Hi,
I am running an i5 4670K in a Z87 UD5H with 8GB of Corsair Vengeance DDR3 1600Mhz RAM. The system was running perfectly up until yesterday when I decided to do some work on the computer that required the removal of the Seidon 120M water-cooler and removal of the motherboard. During this procedure I did not disturb the CPU itself but did remove the RAM and disconnect most of the additional pieces of hardware such as the Graphics Card (MSI 760 Twin Frozr).
After putting everything back together the computer would not boot and I was getting an error code 15 on the motherboard. I checked everything was seated correctly but could not get it through the POST. I tried disconnecting all non-essential hardware and ran the system with a single RAM module in slot 3_1. The system booted perfectly. I started to add more hardware and ultimately was able to conclude that the system will only boot up with a single RAM module in slot 3_1.
If I swap the RAM modules the system still boots okay, but only if the RAM is seated in slot 3_1. If I try moving to any other slot, or any combination of RAM modules other than just 1, the error code 15 is displayed on startup and the system will not boot.
I have flashed the BIOS to the latest stable release (F7), tried the alternate BIOS, reset the CMOS, I also tried removing the motherboard and running it outside the case. Nothing seems to fix the problem. I also tried removing the water cooling system, thinking the frame on the underside might be shorting something, but there was no change.
The only thing I have not yet tried is checking under the CPU for bent pins, but can't think why they would be bent having not removed the CPU during the procedure.
Does anyone else have any good ideas for what I might try?
Thanks!
Thanks!
