cant install wireless network card
25 Nov 2004
Belkin F5D7000
ive tried installing the driver from the belkin site but i just cant get it to show on windows :| it says its there but not installed
riddler said:
Belkin F5D7000
usually you install the part, reboot and then install the driver. i take it it says "found new hardware" when you boot? then what do you do? are you sure you have the correct driver for your version of windows?
In some cases you install the software then shutdown then install the part and boot into windows.This used to be the way with win2k and wireless pci card.
