Can't join a home group - just create???
5 Jun 2005
Southampton
flattened both my main computers and reinstalled windows7, both on the same workgroup and network, however i only get the option on both to 'create' a homegroup
anyone seen this?
One computer has to be the 'host' of the homegroup
So yes, create a new one
i have, i create on either, but on the other one no matter what i only get the option to create, before i flattened i created on one and then clicked 'join' on the other... i dont get a join option
Hmm
Check you've got the latest network drivers on both, check they're both connected to the router and can ping each other.
Check they're both on a 'Home' network type and not Public.
Check there's no 3rd party firewall, maybe reset the Windows Firewall settings. Install all Windows updates on both, then reboot.
Now create a Homegroup on one of them, reboot both machines and see if you get the 'Join' option
Failing that, run through these and try the 'FixIt' thing from MS
http://windows.microsoft.com/en-US/windows7/Why-can-t-I-join-a-homegroup
MMMMMmmmmmm .... last time I ran that MS Fix It software on one of my installs ... it borked it so badly that I had to start with a fresh install all over again :(
yeah everything was set fine, tried again today and was able to add the other 2 to my home group... god knows what that was all about but lost about 3 hours trying yesterday, anyway all is good, thanks for advise.,
