Can't load into Vista
8 Feb 2008
Edinburgh
After trying to install some themes I cannot boot into Vista. It just pops up with error messages after the logon screen although I can ctrl-alt-del and turn off.
Booted up XP (got XP on one drive, Vista on another) and attempted to replace the vista system files that were changed with the original ones. No luck. I set up a system restore point in Vista before I did all this but is there any way to load up the system restore point when I'm in my XP boot? Or is it reinstall Vista time...
I suck.
:o
You could try booting from the Vista CD and running a repair. You can also open command prompt from the CD so there might be a command to restore from a point, you could check that out.
- Pea0n
