I have a 3770k on a sabertooth z77 16 gb 1600mhz ram and ive got to that point on overclocking 4.5 @ 1.220v on manual with other settings of course but il keep it brief to start with
...and in aida after 2hr max temp is 70 and it runs in aida mid to high 60 under full load peeking at 70...
the problem is even if I set 4.7 and take the plunge I was going for 1.270v @ 4.7 with LLc and Phase power on extreme but when I boot into windows its still @ 4.5 under full load of course...and if I use turbo v evo leaving everything the same because it keeps voltage changes but not the frequency
....any help would be a great....ermmm....well help !
thanks guys
DAN
...and in aida after 2hr max temp is 70 and it runs in aida mid to high 60 under full load peeking at 70...the problem is even if I set 4.7 and take the plunge I was going for 1.270v @ 4.7 with LLc and Phase power on extreme but when I boot into windows its still @ 4.5 under full load of course...and if I use turbo v evo leaving everything the same because it keeps voltage changes but not the frequency
....any help would be a great....ermmm....well help !thanks guys
DAN
