Can't Overclock Anymore
7 Mar 2009
e5200 on a gigabyte g31-es2l, worked fine on a 3.33 ghz overlock, recently changed case, moved everything over and now i can't overclock at all.
quick search shows i need to remove the battery for 5 mins or so, as the board doesn't come with cmos jumper.
should this solve the problem or is there another method/solution?
cheers
