Hey all,
It's been a very long time since I last bought a monitor, so I've spent a while researching all the latest tech. I currently have a GTX 970, but will probably be looking into upgrading to the GTX 1070 when it is released next month.
There are almost too many options when it comes to monitors, and the ones that tick all the boxes seem to be very expensive and come with Quality Control issues. TN vs IPS and 1080p vs 1440p - I'm willing to spend the money if it's going to be a quality monitor that will last me a long time.
My initial budget was between £200-300, and I was looking into a 24" monitor - However, with the upgrade from the 970 to the 1070, I'm looking at probably going 1440p, so it'll be 27" instead.
But then I don't see the point in spending £400 on a TN panel, when so many people say the difference between TN and IPS is so big.
I've had my sights on the AOC G2460PG for a long time, and I've been hoping it comes down in price (considering the FreeSync version is almost £100 cheaper) - But the longer I look, the more I'm considering splashing out on a 27" 1440p 144hz monitor.
Right now I'm using a very old 22" television as a monitor, and it stinks - I'm becoming desperate for a decent monitor, but as you can probably tell - I'm confused
Here are some monitors I've been considering:
AOC G2460PG - £290, 24", 1080p, 144Hz, TN - Been in my sights a while, looks fairly reliable, it's within my "budget", but it's 1080p and I'm worried I'll get buyers remorse after I upgrade my GPU and wished I went for a 1440p instead...
Dell S2716DG - £495, 27", 1440p, 144Hz, TN - I've owned a Dell before and their monitors are awesome, but it's almost £500. If I'm spending that much money anyway, surely I should be going for an IPS monitor?
Predator XB271HU - £590, 27", 1440p, 165Hz, IPS - It ticks all the boxes, but reading the thread on here puts me off due to the horrible Quality Control issues. If I spend this much on the monitor, it needs to be perfect.
The price of the 1440p monitors go up so much, I feel like I may as well just stretch my budget even more and go for an IPS monitor. In a perfect world, I'd buy a 1440p version of the G2460PG and it be priced at £300
I have been waiting until after Computex finishes before purchasing, as I had heard about new monitors being announced - But I've heard very little about anything new in terms of 1440p IPS monitors...
Sorry for the long post, but I don't know what to go for
Any thoughts to help clear my mind?
Thanks,
Marky
Thanks,
Marky
