Can't play over xbox live? Connection lost?
13 Jun 2003
South West
Hello :D
I have had my xbox 360 since relase date and have finally tried to play my brother over live today.
I was trying to invite him to join me playing gears of war but when he accepts the invite it says loading then 'connection lost'.
He tried inviting me and I got the same. We tried another game but had the same.
My xbox 360 is connected to my netgear router. I tried playing with the settings in my router incase I was the problem but its made no difference.
Anyhelp with this would be great as I only have a 48hour trial that came with the game!
Thanx in advance!!
BigMac
The usual problem is NAT and routers. I have a netgear router, and have had the same problem, I could not get invited/invites to work, but live seemed OK.
In the end, I manually opened up some ports on the router, and that did the trick! I googled the required ports, but basically they where,
UDP 88
TCP/UDP 3074
Igave my 360 a fixed IP address just to make this easier...
you could just put the 360's ip address in a DMZ on the router...
And you may need the other person to sort their end out as well..
I was quite bemused that a uPNP router needed this, as I could join quick matches etc on live no problems, but hosting and inviting never worked!...
I had this problem, if you test the connection it will say 'NAT- restricted or moderate', sort limits yoru connection capablities, open soem ports on your router, and allow the IP on your firewall and should be fine.
UDP 88
TCP/UDP 3074
Thanx for all the replys!! :D
I have forwarded the above ports and I was able to play my brother today!! YAY!
I did have a problem that I was disconnected a couple of times? Is this common?
Cheers for the help!!
Merry christmas all!
BigMac
