Can't press buttons on car key
17 Aug 2009
Finchley, London
Both my Peugeot 307 keys, the rubber buttons have come off.
I'm at my local mechanics to see if they can do something to fix them. I can get my finger into the longer hole to lock, but not the circular unlock. Well, might be able to use pinky finger. Currently locking and unlocking manually with door lock. I'd imagine buying a new key would be prohibitively expensive?
Well, quickest fix ever. They had a blank and swapped it over. Works perfect. Only charged me a fiver. Doesn't have the silver logo though. Might order one for the spare key. Logo ones seem to be about £4 on ebay.
So the car turned over but wouldn't fire! First time that's ever happened. Turns out the guy had left out a little part when he did the swap which immobilises. He put it back in and all is well. :)
Not that the Peugeot logo matters anyway :D
True! But, nice to have it there anyway.
I looked up what Sugru is. Certainly a good idea, although tbh, still cheaper to replace the case. Can't really think of any other uses I might have for Sugru at the moment either.
