Can't re-use my old Itunes library
21 May 2003
Hi. I've just installed Windwos 7 as a dual boto with win xp.
xp is on C:, w7 is on E: and all my data on D:
in xp, itunes' library is on D:, where all the music is as well.
so in w7, I changed the "my music" folder to point to the one on D:. then installed itunes and started it. and the library was empty.
Looked in the "my music" folder, and the new itunes had overwritten the old library and created a blank one.
So it's looking in the correct folder, but instead of using hte existing file, it replaces the old one. (which luckily i backed up).
Anyone have any ideas??
