Cant read temperatures from 7750
17 Jan 2007
Kent, UK
Hi,
I've just installed a Sapphire Low Profile 7750 in my HP Microserver runing Windows Home Server 2011. It all works fine display wise but I cant read back and temperatures, fan speeds etc. I've tried SpeedFan and GPU-Z and both just give blank values (clocks all 0MHz, 0.0 degrees, fan speed --%). GPU-Z does read all the correct info about the card on the 'Graphics Card' tab but the 'Sensors' tab gives nothing.
Is this because I'm running WHS2011 or do you think there is a problem with the card?
Many Thanks,
Ross
