Cant Replace the Front Bezel on plextor px800a
27 Sep 2005
Just bought a plextor px800a from Overclockers but i cant replace the front bezel to the black one supplied. I used the pin thing to open the tray but now im completley stuck the instructions are crap
any help appreciated
If its anything like my 716SA, then the tray cover pushed off if you push it upwards.
The bezel itself, you need to use a flat end screwdriver and push in the little notches around the top, bottom and sides of the drive.
