Cant see icons when using explorer
30 Aug 2006
I've only found one example so far, but there is likely more, I just have not noticed them.
http://secretworld.wikia.com/wiki/Crafting
This web page should display all the icons for various materials in the blue crafting boxes, they are not showing. They always have before, I think it may be something to do with explorer 10 or the way I set it up. If I click on one of the blue boxes it takes me to a page where it displays the icon at the top left of the page.
Any ideas what I've done wrong (a part from installing explorer)?
Not working in Firefox either so not an explorer problem, would say its the page
eh?
Well definitely not working in mine for some reason - cancel that just cleared my caches and forced reload and it's working now. Have you tried clearing your cache OP?
in IE, if you click the whitespace where the image should be, it will display the image. i have no no idea why they won't show embedded in the page.
Thats only cleared your history
To clear the cache you need to
1: Click Settings (a little cog) > Safety > Delete browsing history...
2:Put a tick in Temporary Internet Files
3:Click Delete
You will then need to force reload the page with Ctrl+R
