- 14 Aug 2012
I recently gotten myself a Galaxy S4 phone as part of an upgrade on my current mobile phone package and I'm planning on using a 64GB MicroSD card that I was planning on using in my Android tablet device but can't as it won't fit into the slot on the device due to their being a problem with the springy bit inside said slot.
The card still has the folders with the media files that I copied via my laptop with Windows 7 (and which I can't use currently because of a problem with the power socket port so I'm having to use my Windows 8 HTPC to access the Internet), but now I have a problem in that Windows 8 won't allow me to copy files like APK's (the filetype that Android apps come in), Zip/RAR files and as a experiment, I tried exe files and they don't work either!
As far as I know, there shouldn't be a problem as I have full Admin rights (Lock Screen needing a password, etc) and I never had any problems transferring this sort of thing in the past for my 32GB MicroSD card for my Galaxy SII phone.
If anyone can give me some advice, I'd be very grateful.
