Can't seem to get the air bubbles out of my loop
Permabanned
9 Mar 2010
Fabric Nightclub, London.
Hi guys, just installed a new pump today, and I have a major problem...
I can't get the huge air bubbles in these pictures out of my loop :(
These pictures were taken whilst the pump was on.
Can anyone help with this please? Thanks :)
If everything is held in properly then you can tip it a lot.
I had mine right up on it's back and almost on its front. As long as water still flows from the res correctly you can really go to town. I suppose you could try flicking & squeezing the tubing etc
i had to rock my case all over to get the air out of my top rad, in the end i lay the case on its side held the res higher than anything else and kept blipping the pump on/off
Could you try switching the inlet and outlet around or will that break the flow direction? Seeing as you seemed to have the same problem with the same tubes for your other pump...
kd
That would break the flow direction, as the rasa has inlet and outlets itself.
I've laid it on its side for now, see how it goes :)
Seems to be working better now, I'll leave it like this for a while, and then continue to shake and stuff :)
