Cant send SMS anymore.....help
16 Jun 2004
For some reason i can receive SMS messages but cannot reply or send new messages...
Its not the phone because its a SIM free K750i on O2 and when i slot my old Orange SIM in, it will receive,reply,send SMS fine...
Any ideas whats going on?.....
Thnx
Have a look in the sticky and check the O2 sms service number in your phone. It may have got changed or stuck on the Orange one.
Yeah you need to change the message centre number on the handset if you are swapping sims - its usually messages > settings > message sending settings > default profile > message centre number (IIRC). Each network has its own number and it needs to change otherwise you can't send messages! :)
thnx....found out what the problem was, somehow my message centre number had got corrupted
it was: 44780209203
Should have been: 447802092035
All that grief because somehow a 5 got deleted...... :mad:
