Can't set larger resolution
30 Mar 2009
Hello all, my last monitor died on me a few days ago and got one of these delivered - VS278H 27" 1920x1080 TN 1MS Gaming Widescreen LED Monitor - Black.
I was basically wondering if it was possible to make the resolution 2440x1440 by any chance, i cant seem to be able to select it anywhere, seems to be maxed at 1920x1080, thank you.
The clue is in the name ;)
The max resolution of that monitor is 1920x1080, the only way you can get a "higher" resolution is by using something like DSR, but you'll still only be able to see 2,073,600 pixels on the screen.
