This is mostly a post i found whilst googling but it describes my problem exactly and far better then i could, i also made a diagram. These are a bog standard home pc and 2 Epos terminals.
I have a network connected with "switch". Network/File Sharing works
Main computer has a "wireless" adapter can connect to internet
OS is Win XP
I am trying to "share" this internet connection to network but when I do
Network Connections > Wireless Network Connection > Properties > Advanced > Allow other network users to connect through...
It says "...A Lan connection is already configured with the IP address.." and
can't share the connection
No other device or computer has this ip: 192.168.0.1
Switch ip range is: 169.X.X.50 and above
Wireless ip range is: 192.168.0.10 and above
Main Computer wireless has the ip of : 192.168.0.12
Main Computer Lan(Switch) ip is 169.X.X.59
Note:
1) Local Area Connection Requires Manual Ip to be entered in order to work to TCP/IP settings - Obtain Ip Automaticaly won't work
2) I can't modify the hardware
What am i doing wrong?
OS is Win XP
Note:
