Hi. Got a slight query here. I can overclock my Q6600 / IP35 Pro to 3.2ghz easily, albeit at 1.425v core with some Noctua heatsink. Probably gets to mid 60's temp wise running prime95.
But recently I've been wanting to tone it down so I wanted to use speedstep to lower the clock while idle, sadly this does not work no matter what I try. Granted it's probably due to the way the voltages are lowered along with the multiplier which is crashing the machine while running my overclock.
As far as I can see running at stock = speedstep and the ability to sleep the machine. However running any overclock above stock causes the machine to crash when it idles and sleep doesn't work. It simply never comes out of sleep.
Am I pretty much resigned to having either an overclock and no sleep/speedstep or stock but with the 2 features mentioned?
Cheers,
Cheers,
