Hi All,
Not really used linux before (use other Unix flavours for ages). Installed latest ubuntu, patched it up. Put it on a static IP range say 192.168.1.100 (server).
Installed ssh - works fine on local PC's. So wanted to test remote connection.
I have got Netgear 834G adsl router. I have port forwarded 22, 23 (trying telnet) and also 1194 (when installing openvpn) to 192.168.1.100.
When I try to ssh on remotely I can see in the netgears log that it has spotted port 22 and forwarded it on but it just times out.
I even moved ssh up to 22222 just in case port 22 was blocked but made no difference.
Did an iptables -L and it showed no entries (default I guess). Installed ufw and added allows for udp/tcp on ports 22,23,1194 & 22222 but that made no difference either.
I've setup /etc/hosts.allow & deny (I know they are working as I tinkered with removing some IP's to make sure the local lan worked/not worked)
So I have another box (Sco) running ssh so I port forwarded the router to this IP and worked fine - the Sco box isn't internet facing so has no firewall etc.
Can't see anything in the log files saying that it's being bounced, or failed entry or anything.
I bet it's something obvious but it's starting to annoy me now
Cheers all.
Cheers all.
