Hi there,
So I've just started using my Z3 Compact again after almost a year and updated it to the latest Android version 6.0.1.
But now I cannot transfer anything to the SD card in the phone. I'm trying to transfer some music and it either crashes and stops responding mid way through transfering or it does transfer but the files automatically get deleted as soon as I disconnect the device.
I've got developer options on, I've tried using File Commander and that does the same thing.
I've also tried using the Sony Companion software to transfer the files and that doesn't work either. And even putting the micro SD into an adapter and trying that.
Literally nothing has worked.
I have no idea why this has happened, the phone settings have been the same since I've had the phone and never once had any problems, only after this android update.
Would really appreciate some help please!
Thanks
Thanks
