Cant transfer to USB flash drive?
9 Dec 2007
Im trying to transfer a 7.25gb .DMG file from my hard drive to a flash stick. I've reformatted the stick multiple times, and when I check its capacity/free space by right clicking and going to properties it shows up as 7.58gb free, 4.00kb used. However, when I try to transfer the .DMG file it says there is not enough free space - How come? :confused:
Go to properties and look at how many "bytes" the capacity of the drive is.
Then go to the properties for the file and find how many "bytes" it says for "Size on disk".
Formatting it in NTFS seems to of fixed the problem - But will a Mac (OSX) be able to read the stick?
EDIT: Nm, seems it can read it fine, just not write. Thanks for your help guys.
