- 31 Oct 2012
- Edinburgh
I've been trying to go from win 7 pro to win 10 pro on my clevo-based laptop and am having trouble so thought I'd ask, see if anyone has any useful ideas. I was getting a 'Missing operating system' error after the reeboot during 'copying files' section of the install from my admittedly non-standard win7 install (bunch of partitions, several drives etc) so took out all but one drive and dropped down to a single partition which win 7 was quite happy with but got the same error. I recalled that by default win 7 makes 2 partitions (one for sys restore) so I destroyed all partitions and let it do it's thing so it'd be as standard a setup as possible.
Now when I try and upgrade I get a 'repairing' message followed by error 0xc000000f and looking in diskpart (list volume) it's got filesystem RAW not NTFS as described here although I've got an extra volume over them marked as hidden (OEM reserved) - possible culprit? Only wiped out partitions via win 7 install CD's partition mgmt options so probably missed the hidden one.
I can do the fix as described in that link to make it report as NTFS but on a reboot it does the same stuff and shows as before. I'm not sure how to fix this
Just to make sure my computer can run win 10 pro I did a clean install and that went absolutely fine so there shouldn't be any reason I can't get there eventually - please help! I'm several full reinstalls in and losing the will
I'll have another go shortly.
