Capable power supply?
2 Sep 2010
Somerset
Sorry if this is a n00by question :cool:
I have a 530W be quiet Power supply and I was wondering if I could run two 6850's in crossfire or possibly 2 6870's?
Cheers
Two 6870's will be using nearly 500w at full load, plus the rest of your system on top of that, you would probably need something a bit beefier.
Techpowerup power consumption test show a 6870 uses 164 watt running furmark, so let's say 330 watt worst case scenario for 6870 xfire, then there is the rest of your system, I think you need 600 watt min.
