Capacitor-less IGZO-DRAM Ahoy!
28 May 2007
This would be the largest technological leap DRAM has ever seen and solve its biggest issue.
The capacitor has long been the problem child of the DRAM circuit, failing to scale with transistor shrinks and requiring lots engineering and material science to solve.
High density dram modules cost a lot(have a lot of chips) and use a lot of power. some servers are liquid cooling the ram to deal with this. The quicker a new way is fired up the better as current dram does not scale well beyond ~12nm and uses a lot of power to keep it refreshed. I would think the big hyper-scalers and AI data centres would be pushing hard for better ram.
A couple of things:
* Calling it "capacitor-less" is misleading. It stores charge in the gate of a transistor. The gate is physically two conductors separated by an insulator, which is a structure that is usually know as... a capacitor.
* The endurance looks too low to replace normal DRAM. They say it's ">10^11 read and write cycles". Let's say the CPU reads a cell, then reads it again after receiving the data (which takes something like 10ns for DDR5) and keeps doing that in a loop. It would take only 1e11 * 10e-9 = 1000 seconds to wear it out.
