14 Oct 2010 at 22:08 #1 delpy8 delpy8 Soldato Joined 7 Jan 2010 Posts 5,114 Location Up NORTH Hi Forum, Can anyone recommend a capture card for the ps3 to laptop as my son wants to youtube his online game play Cheers
15 Oct 2010 at 02:04 #2 eyyaz eyyaz Associate Joined 11 Oct 2008 Posts 1,649 Location London Many people on youtube use Dazzle, i myself have it and it works a treat. http://www.pinnaclesys.com/PublicSi...o+Archiving/Dazzle+Video+Creator+Platinum.htm
15 Oct 2010 at 06:44 #3 delpy8 delpy8 Soldato OP Joined 7 Jan 2010 Posts 5,114 Location Up NORTH Thanks for that
15 Oct 2010 at 09:06 #4 5punk3monk3y 5punk3monk3y Soldato Joined 11 Aug 2006 Posts 5,319 Location Pembs, Wales Dazzle is SD only if you want HD capable then try the HAVA HD capture card
15 Oct 2010 at 11:54 #5 bloodline76 bloodline76 Soldato Joined 7 Feb 2004 Posts 9,539 5punk3monk3y said: Dazzle is SD only if you want HD capable then try the HAVA HD capture card Click to expand... I 2nd this. Very good and lets you actually play in HD too(Still only records in SD though). Unlike the dazzle which you have to play in SD. If you have loads of money spare then you should go for the hauppauge hd pvr. This is the best out there at the moment.
