capture cards
  • Thread starter Thread starter Mp4
  • Start date Start date
Mp4
Mp4
21 Apr 2006
Eastbourne
Hi all,
I bought a capture card from ebay :
Description:
You are looking a brand new 4 channel DVR (Digital Video Recorder) Card. This card allows you to record, view and control images and cameras from your CCTV system or SPY camera system on your computer. You are free to choose any one to record or using the full-automated mode. The images will be stored in MPEG4 format files and stored into your hard disk or removable hard disk. All of them are managed by yourself. Furthermore, there are numerous special functions related to video playback and camera controls, such as video playback/record through LAN, Support PTZ control and remote control, and Alarm controls. For more details, pls refer to the coming manual.
Specification:
High Speed Recording
Simultaneous Recording up to 16 Cameras using 1 card for every 4 cameras
Multi-Mode Display Screen
High Speed Playback Search
Automatic Detection Recording Remote On-line Viewing and Playback via LAN, WAN, PSTN,ISDN, Internet with web browser
Emergency Automatic Display
Alarm I/O interface
Dual Display for Live and Playback
One-channel Audio Input / Recording
Pan / Tilt / Zoom Control
Real-Time Digital Video Compression
MPEG-4 Data Compressing Format
Display Speed Resource: PAL: 30 fps / NTSC: 25 fps
Full Resolution Video Real Time Display: PAL: 768x576 / NTSC: 640x480
One Audio Channel
PCI Controller Card easy to install
Support Color / Black & White Cameras
Support Windows 98 / ME / 2000 / XP
Support up to 4 cards and 16 Cameras on One PC
Data Compressing Format: MPEG-4
Display Speed Resource: 25Frames
Network Connection: PSTN ISDN ADSL
PC Requirement: PIII500/128M/40G
Software Supports: Supports all Windows 98/SE/ME/2000/XP
Package included:
1 x 4 Channels DVR card
1 x software(CD) can free upgradable
Free 4*BNC adapter
This is setup to get a live feed to a bird box in the garden once the camera is connected to the capture card (its connected to an old PC) and the picture is very fuzzy. But if i connect it to an old CRT TV its clear!
I am using this cable also
http://www.thatcable.com/acatalog/info_3_RCA_Audio_Video_Cable_2.html
one end to the reciever (yellow - video / black - audio)
Can anyone spec me a new card or has anyone got an idea why its better on the TV other than the capture card? Other than the card being extreamly poor built
Thanks
Mp4
i is not just because of the details above?
I mean, connecting to an old CRT tv, with a lower resolution, it will look ok, but on a PC, where your resolution is likely 2x that of your camera, its going to look more blocky.
well it is the 1st time i have used a capture card and when its connected to the capture card (i use Active Webcam) the picture is bad the colours are washed out, and i get quite a bit of static. If i connect direct to TV its crystal clear no static what so ever. Any other advice you can give?
