I've always used Fraps on my main gaming rig to record gameplay footage to a dedicated 2TB WD Caviar Black. I edit purely with Sony Vegas and output file is saved to 1080p MP4 at 12Mbps with AAC audio at 48KHz sampling, 320Kbps bit-rate. My gaming sample rate is 96KHz/24-bit from the Phoebus. These settings are used because I appreciate high quality.
Put simply, I'm after a device that doesn't affect the performance as much as Fraps with all the overheads so that I can retain normal high ingame settings and maintain smooth performance because faffing with that all the time means I always wasting my spare time. As a bonus there's years of classic freeview content (non-HD) to take off my box and pop onto a DVD or bluray disc. Will also store them on my media server as backup to avoid my efforts being lost.
It's noted that the Elgato Game Capture HD is a popular solution that is able to support 1080p and record at 30fps with 60fps passthrough. I'm unsure if this is the best solution and it has crossed my mind regarding a dedicated capture card but that's a different kettle of fish
Could someone enlightening me if Elgato would work using it on the same PC for gaming using dedicated HDD (there's a dedicated 3570K+GTX650Ti Folding rig I could take offline if needed), and anyone know about capturing Sweetfx effects this way?
Thanks
Could someone enlightening me if Elgato would work using it on the same PC for gaming using dedicated HDD (there's a dedicated 3570K+GTX650Ti Folding rig I could take offline if needed), and anyone know about capturing Sweetfx effects this way?Thanks
