Capturing Audio
16 Aug 2005
Nottingham
Before we start, here is my system spec:
AMD Opteron 148 CABYE @ 3008mhz.
DFI LanpartyUT nF4 Ultra-D
2 x XFX GeForce 7800GTX 256MB
1GB GeIL ONE PC3200 TCCD CAS 1.5
2 x WesternDigital 250GB 16MB Cache
2 x Hitachi Deskstar 160GB
SeaSonic S12 600W
Onboard Karajan 8ch
I have a JVC Video camera here with me that cant connect to USB, only S-Video and Composit.
I can rip videos threw the S-Video no problem, but can i get the audio can i hell, i have tried so many combinations i have tried 4 programs to get audio it wont pick up anything.
I have a Phono lead red and white both ends, plug red in Comp Vid out and Comp in on video card, i get video no problem, i plug ther white into a phono - headphone jack plug it in Microphone, picks up no audio, line in no audio, i have even tried plugging the cable direct into S/PDIF in.
I have tried capturing audio in: Virtual dub, Sound Recorder, Windows Movie Maker, Audacity.
I cannot get this thing to pic up any audio thats being played into it, i know there is audio when we recorded it, ive watched it on my TV
does anybody know what the hell is wrong man its driving me insane
have you checked what your sound card is set to record from ?
if you have leads plugged into microphone jack on the pc, u will need to set your sound properties to record from microphone
control panel/sound and audio devices then under device volume click advanced button.....
then in the volume control box click options and select properties, then click recording and tick the relevant boxes/ click ok then tick the box under the microphones slider
hope that all makes scence and there is probably an easier way to do it lol
Records from AC'97 which is sound card.
Ive ticked microphone, line in, i get nothing it wont pick up nothing at all
every volume is turned up full.
in my quest to sort out my sound issues i ended up buying a 2nd, cheap 5.1 card and this just made them go away.
could this help him?
Same board in use here, Just to confirm it's the pink socket that works.
I'd double check sound output is coming from the cam 1st, hook up to a telly preferably, if thats ok then try a different source for the comp, microphone/mp3 player or something and if all that fails try reloading the drivers for the nf4.
A real pain in the a$$ to check but is the karajan sound module attached ok?
/Edit
Just had a thought, when i ran my dfi at a high htt (>290 iirc) the sound crapped out.
my system is not overclocked at all so im at 200htt.
audio off pc works fine i can play my music, yes the audio modual is attached fine, its very easy to check no pain for me as my pc looks like this atm:
sound definatly comes from the video camera 101% sure on that.
tried what mark said, still same it pics up nothing at all.
Pink = microphone - nothing
Blue = Line IN - nothing.
any other suggestions untill i get my expert back from RMA
/Edit
Try; buy a cheap 5.1 or better still a decent one so you can use pci
