Capturing S-Video
10 Nov 2004
Kent, England
Hi,
I'm having trouble capturing video from an s-video connection on my graphics card. Got a Canon G45 Hi8 and plugged in s-video to the port on my laptop. Trying to use some video capturing software but nothing will pick it up!
Help!!
I've tried on my PC - Geforce 6500 and my laptop ATI radeon 9000.. can't seem to get it to work. I've used a few bits of software to try and see the camera.
Not sure if I'm meant to see it in the device manager as it isn't a plug + play device.
you won't see the camera if your using s-video in to attempt to record. you'll have to start up the program you wish to record with select the s-video input as the source and then press play on the camera.
I dont think many graphics cards allow capture from s-video (could be wrong) but I think you need a capture card - and some software that will allow analogue capture.
Hi there
If I recall correctly I used a firewire card, and connected S Video on camcorder direct to the firewire card.
Hope that helps
Connected S-video to the firewire card? wow didnt know that was possible, i ordered a capture card today (arrives tomorrow, external USB device) so hopefully this will allow me to do what I want to do with the camera.
slightly off topic is the G45 model the one with `eye control`?
had one a few years ago untill it died :( loved it to bits focused on what you looked at and you could choose menu settings etc just by staring at a menu option.
do they make any models like that nowadays? :)
Justin said:
The S-Video socket on graphic cards are outputs not inputs, so you need a capture card.
spot on , I've never heard of anyone capturing video on SVHS on a graphics card .The only true way to capture from a digital camcorder is by using a Firewire card or a TV card if using an older analogue camcorder .
