Capturing xbox360 via a USB capture device?HELP?
30 Dec 2003
HI all, i fancy capturing my xbox360 in action on halo2 so i can create a montage, is thie such a device that i can plug my component into then output so i can plug into my telly? Also i have noticed that if i de select the HD switch on the scart then it outputs on both compnent and av :) i need to know whats the best way for me to capture me playin?
thankz!
Adam Senior said:
i still want to play using my tv, i dont want to lose quality basically, i still want to play on my 32"sammy
Composite quality on the PC is fine. You are going to be compressing the image surely so that you can distribute it across the web.
You will not notice that much drop in quality by having the component cable to your TV displaying non HD images it would be similar to haveing a RGB cable. On the Xbox I dropped from RGB to composite on my TV for montage work. and reverted back after. It did not hamper my gaming ability.
I'll be home in about an hour so if you post your GT I can talk you through it then.
