- 19 Aug 2004
- Stockton-on-tees
Ive been noticing lately as the weather is warmer that my AC is non existent temperature wise, it turns on and ive checked the compressor spins so i presume its working but theres no difference in temperature with it on or off and the low pressure pipe is not cold to touch after its been on awhile (ive seen that it should be frosty to touch after reading on the net). On a mild/warm day its between 15-23c out the vents, i had it regased last year as it was not getting cold and as far as i can remember it was cold after it had been regased. It was actually completely empty when the did it, something like 0.07ml of gas was recovered.
Ive bought a STP hose/gauge to check the gas level and its showing right on the low/filled mark at 25psi so im wondering does it sound like it needs a regas again or could it be something else if so what could i check for next. Could the compressor spin but not pump the gas around? or could the gauge be showing more than is in it and its a false reading?
thanks
thanks
