Hi, got my car MOT'd after having a fair bit of work done to it:
Plugs
Oil + Filter
Brake Lines
Ball Joint
Some Mounts (to stop gear knob shaking)
Windscreen crack
Brakes cleaned (sticking)
Lambda Sensor
Headlight Alignment
Some Bulbs
Cost of 2 MOT's
And some other stuff .. It all cost £240 which I thought was ok!
Anyways, now at idle it seems a bit shakey or 'groggy' If I put the gas on till 1000RPM it makes the car shake and vibrations through the wheel!
It's very annoying when pulling away because of this (the clutch is slipping but this isn't the problem as it does it in neutral too) If I put my foot fast on the accelerator it does it too more violently..
What the heck is wrong with it? He drove it up to me, why didn't he notice? Surely it has something to do with fueling? Any one got any ideas? Think I'll take it back tbh but just need an opinion. ( M Reg Clio 1.4)
Thanks.
Plugs
Oil + Filter
Brake Lines
Ball Joint
Windscreen crack
Lambda Sensor
Headlight Alignment
Some Bulbs
Cost of 2 MOT's
Thanks.
