Car Alarms & immobilisers
18 Oct 2002
Dublin, Ireland
Hey,
After a few cars have been broken into around me, and the fact that I love my car, I want to fit an alarm/immobiliser.
Ideally, I'd like to do it myself (it's a Mini, it's not too complicated :) ), so are there any good deals about the place? What brands are decent?
I've seen no name car alarms on the bay for £20 incl postage, but surely they're going to be complete tosh?
Ideally it'd come with a provision for remote central locking, as I want to fit central locking in a few weeks.
I can get a laserline alarm/immobiliser & have it fitted for about £140 (what my mate got in his), but I've heard lots of bad things about them - another friend had one fitted and armed when his car got stolen...
All help/advice is greatly appreciated!
Mark
I fitted a Laserline to my old car. You don't hear of them anymore, but a couple of years ago there were a fairly decent budget brand.
I'd definitely recommend them. Mine had loads of features, and a built in immobiliser. I'd find out the model number but everything is at the new house.
I paid £50 for mine and it was well worth it.
go for a TOAD AI606 mate its Cat1 and costs about £100 to buy (plus fitting), you just have to get it fitted by a pro do they can stamp the certificate.
I'm kinda scared of the laserline, because my mates car was taken whilst having their alarm/immobiliser system fitted.
My mate has an old cobra alarm he said I could have - are installation instruction manuals easy enough to get on the net?
Agw - how long did you take to fit the system and how easy was it?
get it fitted then its certified for your insurance you might get a discount, next time buy a car with one a standard so much less hassle
A friend of mine has a Cobra on his car. He paid £300 for it (inc fitting). Seems a good kit, but I would have rather got a Clifford for that price.
commited, errr, it took me about 6 hours in total to fit. That was over a couple of days though. The first day I simply connected up power/earth, the siren and the internal sensors. That was the easy part, took about 2 hours to get it all nice and tidy.
Having to trace wires from behind the fusebox for the indicators and door switches was the hard part. If you have a Haynes manual for your car and can read wiring diagrams, it'll be much easier though.
I was a total car n00b back then and I didn't find it too hard. I even went on and fitted a system in a friends' Punto :) That took me about 4 hours.
I asked for a quote with/without an alarm and there was no difference with my insurer.
Quite frankly, that is a bit of a ridiculous statement with regards the choice of car - I put condition of car and engine far higher than optional extras, and a Mini in the same nick as mine is very very hard to find ;)
I've said if I can get the cobra to work, I'll throw some money at him, and if I dont, I wont! I might try it as the risk free but time consuming option!
It should be more straight forward on the Mini - I have haynes and can read wiring diagrams to a reasonable level!
I should avoid cheap no-name systems I assume though?
Some insurers ask for a manufacturer's approved offical fitter certificate but then others dont even ask if you have an immobiliser.
agw_01 said:
I think the AI606 is a little more expensive than £100 mate. Especially to get it fitted.
have a look on ebay mate, they are £102 BIN.
not sure how much fiting will cost though!
