Ive got a new car and want to hook it up with a sub and2 rear speakers do i need an amp , im sooo confused what do i do/buy can anone point me in the right direction please . thanks
Once you buy an amp + speakers fitting them is the hardest part gimme your budget and what type of sound you want and it would be easier
It can be a little confusing at the start as i was in the same situation so ill try and tell you what ive learnt.
First you need to run a high gadge wire from the positive terminal and hook it up to your amp.
Then you need to run a small wire from from amp and connect it to the remote control wire coming out of your wire loom, This is usually a blue wire and has a label on it at most situations.
You now need to run 2 more wires from the pre amp outputs on the back of your head unit and connect them to the amp.
Fitting the speakers is the easiest part, Once youve chosen what speakers you want, you simple connect them to the amp using simple speakers wire. Negative to the negative and positive to the positive.
If anything is unclear say and ill try to explain in a little more detail.
